Throttle rod on a M-H Pony
Jeff Oliver
04-19-2002 03:10:32
We just bought a Pony that has already been restored and runs great. The problem is that the throttle is real touchy. When we got it the rod that connests the throttle lever to the governor was loose at the governor and has a nut on the end. We used washers and tightened it up but got to looking closely and it seems it has a spring on it also. Ours doesn't have one. It would make sense for it to as the throttle should work smoother if it did but I was wanting to know if anyone knows for sure and if so what kind nd how much tension should the spring have?
thanks!!
