Restoration & Repair Tips Board
oil blowing out of exhaust pipe FARMALL B
Paul Littlejohn
08-20-2007 11:36:06
Farmall B has oil blowing up exhaust pipe. Starts almost immeadiatly and gets worse as it heats up. Is this the rings or valves or both or what??? Thanks.
old
08-20-2007 12:27:45
 Re: oil blowing out of exhaust pipe FARMALL B in reply to Paul Littlejohn, 08-20-2007 11:36:06
Rings or valve guides will cause that. Thin oil will also cause that. Do you shut off the gas when you park it?? If you don't you better check your oil and make sure its not 50% gas and if so that will cause oil like that and also blow up the engine to boot
