Restoration & Repair Tips Board
coolant leak jd 520
James Pearce
08-15-2007 15:52:27
I have a jd 520, runs great, last time a drove it, after shutdown, it started leaking coolant out of the breather tube and possibly other places, the leak continued until most of coolant leaked out. Does anyone have an idea what is wrong. Could it be a head gasket, ruptured manifold??? What should I do to diagnose the problem? Thanks
soundguy
08-16-2007 10:07:32
 Re: coolant leak jd 520 in reply to James Pearce, 08-15-2007 15:52:27
A compression test will help you pinpoint a blown head gasket.
If you think it is a 'wet stud' leaking at the manifold.. you could pull that and chack after the compression test.
DO check to make sure you do not have coolant in the oil.. or setting in the cyls.. if in the cyl.. you are headed for hyd lock..
Soundguy
james pearce
08-16-2007 17:50:07
 Re: coolant leak jd 520 in reply to soundguy, 08-16-2007 10:07:32
Thanks for the reply, the engine seems fine, the coolant all ran out on the shop floor. Do you have any thoughts as to what is broken that would cause this type of external leak?JRP
soundguy
08-16-2007 21:07:37
 Re: coolant leak jd 520 in reply to james pearce, 08-16-2007 17:50:07
Not much more past what i already mentioned..
Soundguy
