Restoration & Repair Tips Board
cub idle air screw setting.
kelly miller
07-15-2007 18:18:59
Hello I would really appreciate it if some one could tell me the base setting for the idle air screw on a 53 cub. When I got it the screw was not in there so I could not do the turn in and check. Any help would be great. Thanks
Kelly in PA
Jake T.
07-16-2007 16:35:17
 Re: cub idle air screw setting. in reply to kelly miller, 07-15-2007 18:18:59
I don't have a manual in front of me but, I would start with the screw turned all the way in. Turn it in until it seats. Back it out about 1-1/2 turns. Start it up. Let it run at a fast idle until warm. Now throttle down to idle. Turn the screw in either direction until the engine reacts to the change. When it starts to lope turn the screw in the opposite direction until it starts to lope again. Turn the idle screw to the midpoint and you should be running pretty good. At this point you can tweak it a little more until it's where you like it.
Jake T.
