Restoration & Repair Tips Board
engine on ac all crop
wally b
06-19-2007 13:30:52
Well I found an all crop harvester (4 actually, enough to make two whole ones) I don't know much about motors though.
The engine may be stuck. Getting is unstuck may be a problem , but after that how hard are those engines to get running? Is it somthing an engine novice could do with some knowledgeable neighbor's help?
wally
YTSupport
07-12-2007 06:34:17
 Re: engine on ac all crop in reply to wally b, 06-19-2007 13:30:52
Forum Test please ignore
Daniel H.
06-27-2007 18:40:41
If it has an AC engine, I believe it is the same as a "B" Allis tractor. That should help with parts and finding relevant posts. Also, if you are fixing it to use, many were converted to run off the PTO, once tractor had "live" PTO and enough hp. This was you don't have to worry about the power unit.
Gene Davis (Ga.)
06-19-2007 18:57:24
The answer to this question is dependent on how badly they are stuck, how determined you are and how skilled your neighbor is. The best advice will be to think twice and move slowly once! There is lots of good sadvice on this board for freeing stuck engines of all kinds look extensively in the archives.
