Restoration & Repair Tips Board
Super MTA transmission
Joe Rasmussen
06-11-2007 12:25:41
I have had the Farmall SuperMTA I grew up with being restored for the past two years. I finally got it and immediately the transmission locked up. The gear shift appears to move between 4th and 5th, but it really seems stuck in 2nd. The gear shift will not move to the left, and remains between 4th and 5th, and I can't even get it to go into neutral. I am really bummed after waiting so long for it. Any suggestions?
Greasey Hand
08-14-2007 19:28:25
 Re: Super MTA transmission in reply to Joe Rasmussen, 06-11-2007 12:25:41
1 of the rails is wore where the shift lever goes in take it out & weld the edge up you will be able to see it, I wild them with SS.
ih650
06-11-2007 13:18:48
The shifter is worn and the trans is stuck in 2 gears. Pull the shifter out and you can use a pry-bar and get it in nuetral. You have to drive the cross-pin out and lift the shifter out.Good luck.
