Restoration & Repair Tips Board
Touch-O-Matic Problems on early JD M
John Moore
06-01-2007 19:13:10
Just wondering if any of you guys have experienced this problem. Would like to hear your comments before I start looking into the Touch-O-Matic system. Tractor had been idle for years. Got engine running and noticed a rag stuffed in Touch-O-Matic oil filler pipe blew out into the air. The draw bar could be raised or lowered by hand. Decided to restore tractor and arrived at the point to start engine again and check Touch-O-Matic system now filled with fresh oil. Results: Started engine and the draw bar moved to the full upward position; there is no response to the hand control and hydraulic oil is flowing out the filler tube. Placed over 400lbs on draw bar to lower it with no results. Any comments appreciated. John
