Restoration & Repair Tips Board
Starting Problem
roadrunner1443
05-25-2007 16:33:24
I pulled int a parking space and hit the curb with the front of my 1993 Cutlass Oldsmobile. I shut the engine off and left, when I returned the engine wouldn't start. It turned over hit a couple of times, but never started. Do you think the fuel shut off when I hit the curb? If so, where is the reset button?
I know this isn't the right site or forum, but is the only place you can get a good answer.
Thanks!!!
Roadrunner1443
Jon Hagen
05-25-2007 17:46:05
 Re: Starting Problem in reply to roadrunner1443, 05-25-2007 16:33:24
I dont think GM ever used that crash/fuel shutoff system, that was mostly Ford. Your problem is elswere, verify if you have fuel and spark. If high miles, you may have a worn out in tank fuel pump.
roadrunner1443
05-25-2007 20:32:11
 Re: Starting Problem in reply to Jon Hagen, 05-25-2007 17:46:05
Thanks for the information Jon. I should have explained in my original post that it was firing fine, just not getting the fuel to run.
Thanks
roadrunner1443
