Restoration & Repair Tips Board
diesel leaking into the crank case?
whit
05-14-2007 21:13:39
I have a 460 international utility that I just picked up. I went to check the oil and I found that it was full of diesel. The injection pump is a rebuild/new, and when I bought it the oil/filter had just been changed. I have only run the tractor for about an hour when I relized the radiator was leaking radiator fluid so I stopped and it has sat for about a week torn apart now and it is filling the crank case with diesel any wisdom as to what could be the problem would be greatly appreciated.
thanks whit
old
05-15-2007 08:10:32
 Re: diesel leaking into the crank case? in reply to whit , 05-14-2007 21:13:39
If it has a fuel pump on it that could be bad and or the seals in the injector pump may have got damaged when it was installed and that can also cause that problem. Either way don't run it till you fix that or the engine can/will lock up on your BTDT and found out the hard way.
