Restoration & Repair Tips Board
farmall 140 on two cyl
tim edwards
05-13-2007 11:18:18
My newly purchased 140 seems to be running on two cylinders - I have replaced the distributor due to rusted drive gears and re-timed with new points and condenser it shows some spark on all four and compression is fine - adjusted the valves too. but when i pull the plug leads off the center cylinders there is no noticeable change in rpm the cylinders are much cooler than the outside ones according to my heat gun. it had a 12v battery with a regulator that changes the input coil voltage to 6v could i remove this and run 12V to a new 12v coil? are condensors voltage specific? any help in this would be appreciated....
