Restoration & Repair Tips Board
NAA oil pump
TBJ
04-18-2007 16:41:40
Hi all: Any way to test an oil pump while it is off the tractor? Have an NAA ford that has no oil pressure. I checked the lines, all clear, oil gauge good. I removed the pump cleared the relief valve, now I would like check it before putting it back on. Any help would be appreciated. Thanks
Dardan
05-08-2007 09:31:31
 Re: NAA oil pump in reply to TBJ, 04-18-2007 16:41:40
Do you still need help on the pump? If you do, I have the specs to check the pump with feeler gages.
Bob
04-18-2007 20:23:57
If the pump does not appear badly worn,it should work OK. Pack some Vaseline in the gears or gerotor before reassembly, to help it prime.
