Restoration & Repair Tips Board
how to clean inside of a radiator ?
panterinsky
04-14-2007 12:45:55
I have a 49 John Deere MT and when I took the raditor out there was a lot of rust sludge at the bottom return hose. It looks like it has years of abuse and maintance. My Uncle said it used to get hot when out in the field now I know why. It dosen't look like it has been flushed for years. Will I have to have it dipped or is there any thing else I can do to get rust out of the radiator? Thanks
Oldmax
05-14-2007 04:51:02
 Re: how to clean inside of a radiator ? in reply to panterinsky , 04-14-2007 12:45:55
And if what what Old told you doesn't work take to raditor shop have boiled , routed & presure tested .
old
04-14-2007 14:34:21
Well if you have it in the radiator you will also have it in the engine. What I do is fill the system with vinagar then run it till good and warm, let cool then drain then if you can bacl flush it by hooking up a garde nhsoe to the block drain and letthe water flow for a couple hours. Some times if real bad you have to do the vinagar a couple of times.
