Restoration & Repair Tips Board
Voltage regulator
Ross Longyear
04-05-2007 11:24:44
Would like your help in locating a 6 volt positive ground regulator. This is for a Waterloo Bronco tractor. It has a two cylinder Wisconsin engine with the regulator sitting on top of the generator.
Any help would be great. Ross..... ..
souNdguy
04-05-2007 12:07:50
 Re: Voltage regulator in reply to Ross Longyear, 04-05-2007 11:24:44
A circuit or B circuit..what are the max charging amps.
If it is A circuit.. and low amps.. why not try a VR off a JD-B... they are low charge rated.. less than 10a.. etc.
soundguy
