Restoration & Repair Tips Board
MF 245 Tractor Brake Drum Screw Removal
Roger Johnson
03-26-2007 17:26:40
How do I loosen the two slot screws, holding the Brake Drum on? I have only tried to turn them left. I tried using a large flat head screw-driver and hammering with a punch. No Luck?
djw
04-02-2007 03:21:46
 Re: MF 245 Tractor Brake Drum Screw Removal in reply to Roger Johnson, 03-26-2007 17:26:40
Roger, I normally use a cold chisel and catch a corner of the screw and strike it till I"m able to unscrew it . I usually have to replace the screw. Dave
The Preacher
04-02-2007 18:33:53
 Re: MF 245 Tractor Brake Drum Screw Removal in reply to djw, 04-02-2007 03:21:46
Try using a hand-impact driver. I've had luck with them in the past. Just get a few extra bits, and don't be upset when you break one. They work really well when properly used. Any good hardware store or tool dealer should be able to get one.
