Restoration & Repair Tips Board
Off topic: removing old tin
Moline_guy
03-08-2007 18:20:12
Need to put new steel on one of my old pole barn roofs, just wondering if anyone has tricks to pulling off the old tin quicker than one nail at a time with a pry bar. Thanks for any replies.
RUSSELL TANNER
05-17-2007 18:31:55
 Re: Off topic: removing old tin in reply to Moline_guy, 03-08-2007 18:20:12
DEPENDING ON HOW OLD AND HIGH THE ROOF IS FROM THE GROUND. I HAVE USED A LONG WOODEN 2X4 AND STARTED AT THE OVERLAP EDGE AND BANGED NEXT TO THE LATHE FROM BACK TO THE FRONT AND THIS KNOCKS OUT THE NAILS AND THE TIN FLIPS OVER AS YOU GO.
glennster
03-09-2007 09:43:58
we took a pole barn down a few years ago and moved it. i built some pullers using the hoof clippers and picked up some inexpensive slide hammer dent pullers. i welded the dent puller to one of the handles on the hoof clipper. you set the clipper over the nail, tap in to slide the clipper under the nail, squeese the handle, then pound back with the dent puller. two or three hits will pop those ring shanks right out. we took down a 60x120 morton building this way. goes quick once you get the hang of it.
sjh
03-08-2007 19:23:56
If the nails have the rubber washer on them a hoof clippers cutts them right off.
