Restoration & Repair Tips Board
Weight Gaurd for 400 International
Trent Anderson
03-05-2007 08:16:19
I was wondering if anyone could tell me if you need the weight guard on the distributer? I called the dealer and they discontinued the part. The originail one is bent up and what happened is the screw that holds it came out and got into the weights and locked up the distrubuter and broke the drive gear pin and ruined the shaft. I ordered a new shaft and was wonder if I need the gaurd Im afraird that it will do it again and if thats why they dont make it now more because was this a normal problem ? Thank You
old art
03-16-2007 15:41:35
 Re: Weight Gaurd for 400 International in reply to Trent Anderson, 03-05-2007 08:16:19
you can put loctight on the screwto keep it tight to remove screw later you take a hot soddering iorn and hold onthe screw head for a short time it will come out
