Restoration & Repair Tips Board
Plexiglass
Willy P
03-04-2007 18:45:03
Can you remove scratches from plexiglass and if it can be done, How? Thanks
ben4511
03-08-2007 19:57:16
 Re: Plexiglass repair in reply to Willy P, 03-04-2007 18:45:03
I have removed many scratches in aircraft plexiglass. Aviation suppliers have a sandpaper kit you can purchase or maybe make up your own.
Start with a coarse sandpaper , about 200, then use finer and finer paper for each step, always going at approx 60 degree angle to previous step.
As I recall the finish sandpaper was about a 2000.
basically smooth-- then polish. McGuires is one polish available. Do search for aircraft supplies.
'Aircraft Spruce & Speciality" probably sells it.
Lots of work, but can be done.
CalJim
03-04-2007 20:53:34
 Re: Plexiglass in reply to Willy P, 03-04-2007 18:45:03
Forget it for the most part,unless the scratches
are really light,then you can use the canned stuff. Any agressive buffing will distort the
plastic..... . CalJim
Davis In SC
03-04-2007 19:18:18
Motorcycle shops sell some cleaners and scratch removers for plastic windshields..
old
03-04-2007 19:07:19
Yep can be done but it takes a lot of work and a lot of time. Best thing I have found its tooth paste and a soft rag and work and more work. I had a watch that I messed up once and I used tooth paste on and got it clean as day again but it took a lot of work and time to do so. Some how payment and 55MPH and a motor cycle doesn't work well. Very long story but any how thats how I did it
