Restoration & Repair Tips Board
ticking in motor ford 9n
ratt66552
03-01-2007 05:35:33
i bought a 9n with a ticking sound in motor i rebuilt the oil pump, it olny had about 5 psi now it has 40psi oil pressure but it still ticks checked the valves they were fine the throttle after it warms up does not work properly it wont idle down and the ticking sounds like it comes from the part where the governer links to the carb front and right side(if sitting on tractor)of motor(generator side) its a 1947 9n
RUSSELL TANNER
05-17-2007 18:44:29
 Re: ticking in motor ford 9n in reply to ratt66552, 03-01-2007 05:35:33
IF YOUR TRACTOR HAS HAD A DELCO ALTERNATOR ADDED, INPLACE OF GENERATOR, LOOK AND SEE IF THE COOLING BLADES MIGHT BE TOUCHING THE BRACKET
Turke Bros. Farms
03-01-2007 13:48:51
Could be a BOMB!
old
03-01-2007 11:33:59
First off it can't be a 1947 9N because the last year 9Ns where built was 1942. Now that said it could be a 1947 2N. You most likely have a bad govanor and when they go bad they can make some odd noises. 9Ns where made from 1939-1942, then in 1942 the 2N came out and was made from 1942-1947 and in 1948 the 8N came out, there where a few 8Ns made in 1947 but there still called 1948s. The 8N was made from 1948-1952 when the Jubilee came out in 1953
ratt66552
03-02-2007 06:47:55
 Re: ticking in motor ford 9n in reply to old, 03-01-2007 11:33:59
thanks for the info how would i know what year and model i have the tag by the steering wheel is not readable i found some letters and numbers on my engine block starts with 1-9n my left axel tube(sitting on tractor) reads 47 9n i am lost what parts in the govener wear out i am new to the tractors please help thanks
old
03-02-2007 07:30:03
 Re: ticking in motor ford 9n in reply to ratt66552, 03-02-2007 06:47:55
Tractor serial number is on the left side of the engine block behind the oil filter. Its stamped just below the head. It will start with 9N and look sort of like this 9NXXXX. Then take that number and look in research&info on the left of this page then serial numbers then ford then 2N and see where that number fits in.
ratt66552
03-02-2007 14:13:07
 Re: ticking in motor ford 9n in reply to old, 03-02-2007 07:30:03
thank you "old" for the knowlege my tractor is a 1947 2N i purchased a shop manual today what a help thanks again
