Restoration & Repair Tips Board
allis chalmers model g
jim eastham
02-26-2007 09:00:17
can anyone tell me where the engine oil pump is located on the model g? i have lost oil pressure for some reason.
Gene Davis (GA)
02-28-2007 18:19:55
 Re: allis chalmers model g in reply to jim eastham, 02-26-2007 09:00:17
The oil pump on the Continental N-62 series engine is driven from the end of the camshaft at the rear of the block. Relief valve is under nut at the side of the block on the rear side of the N-62 in my Earthmaster tractor.
soundguy
02-27-2007 07:59:49
Did you just change the oil filter and perhaps use a new paper pleated on instead of the floss packed one that for instance.. fram sells?
Soundguy
J Schwiebert
02-26-2007 16:37:11
I have heard of that problem before on the N series Continental engines. If I remember correctly the oil pump is driven off the back of the cam shaft. You may need to prime the pump or prelube the engine with an outside tank. More questions?
