Restoration & Repair Tips Board
MF65 - Front Pump for Loader
Rob Six
02-14-2007 09:40:52
I have a MF65 which has a front loader with a pump that runs off an adapter plate on the crank. I do not know the brand name of the loader or the pump. The cover plate on the shaft side of the pump is cracked and needs replaced or thet whole pump needs replaced. The pump works great if I could find a replacement for the drive side cover plate.
The pump has the part # P319EH56L01 stamped on the outside of it and the drive shaft cover plate which is great has the part # C3P 1074C stamped on the inside of it.
Does anyone know anyone who carries salvaged pumps or who would know anything about what I should do either replacing the drive side cover plate or the entire pump.
Joe(TX)
02-16-2007 08:35:41
 Re: MF65 - Front Pump for Loader in reply to Rob Six, 02-14-2007 09:40:52
Surplus Center may have a pump that would fit. Most pumps used are a standard mounting. It would be ccw rotation. I'm not sure who made the pump. Probably a Hydreco. You might check with a hydraulics repair shop.
I'm sure you could get the part from MF.
rob six
02-14-2007 09:45:51
One more thing..... ...I do have picture of the pump if they would help anyone in identifying it..... .thanks!
