Restoration & Repair Tips Board
lpg regulator freezing?
pullin705
02-12-2007 16:34:37
I am working on my propane system and as soon as I turn on my propane the regulator instantly freezes and the carb doesnt get any fuel, and advice is appreciated, thanks
ken in texas
02-14-2007 17:10:42
 Re: lpg regulator freezing? in reply to pullin705, 02-12-2007 16:34:37
Be sure that you always open the vapor valve first.Start engine full throtle and full choke.after starting slowlyreduce choke and throtle and let run until the water lines to regulator warm up. then slowly open liquid valve and close vapor valve. If this dosen't solve problem,mabey the water lines to regulator are pluged.
phil lowe
02-14-2007 15:47:15
if your reg. is freezing you 've got mosture in your LPG ..at work we would drive the methel hydrate through the system ,(with nitrogen to drive it) ..it picks up the mosture ..
WE use alittle device called a freeze valve which lets little bit of lpg bleed off,, if it freezes up in under a minute there's to much mosture in it ,, then gotta hit er with alcohol
135 Fan
02-12-2007 17:24:46
Are you drawing liquid or vapour from the tank? Too much flow might make it freeze fast. A lot of propane systems have heater hoses going to them to stop the regulator from freezing. Dave
RayP(MI)
02-18-2007 11:44:27
 Re: lpg regulator freezing? in reply to 135 Fan, 02-12-2007 17:24:46
Try warming regulator with a heat lamp before flowing lp.
