Restoration & Repair Tips Board
overhaul
jd 60 boy
01-12-2007 08:02:54
I am thinking about overhauling a 1954 JD 60. could anyone give me a good ball park fiqure on how much this might cost me if nothing is needed to be done to the block. Thanks
glennster
01-12-2007 08:45:05
 Re: overhaul in reply to jd 60 boy, 01-12-2007 08:02:54
i browsed up thu the parts located on this site. the piston kit will run about 375.00 or so, another 125.00 for the gasket set. figure if you need to bore the block and do the valves, maybe another 125 to 200.00, so guess around 800.00 or so. but, my luck, i'd wind up turning the crankshaft, and the clutch would probably fall out on the floor in pieces. so add another couple hundred just to be on the safe side.
