Restoration & Repair Tips Board
spark plugs broken off
super red
12-26-2006 15:08:09
I was changing plugs in my 200 and 2 spark plugs broke off at the threads in the head . I tried an easy out and that dont work and I soaked it with penentrating oil also .
Glen in TX
12-27-2006 08:23:02
 Re: spark plugs broken off in reply to super red, 12-26-2006 15:08:09
Be sure to fish around with a magnet after you get it out to pick metal pieces in cylinder. The heat or cutting slots in it should let it come out. Good luck.
the tractor vet
12-27-2006 07:02:20
If you have a tourch then just heat the broken plug base up cherry red and let it cool and screw it out no need to remove the head.
Wayne Swenson
12-27-2006 06:04:29
Take a Dremel tool with a carbide bit and gently cut 2-3 slots in the threaded portion left in the head. Now take a small chisel and collapse the thread into the hole. Get 1 piece started and you can turn the rest out.
Next time use Anti-sieze on the threads, right?
MarkB_MI
12-26-2006 19:29:58
You are going need to get some heat on those plugs to get them out. Judicious application of an acetylene torch will do wonders.
I would seriously consider pulling the head at this point. That will allow you to get to the other side of the broken plugs and clean up any exposed threads. You can also partially thread the insides of the broken plugs with a tap, then screw a bolt into the plugs and put some real torque on them. Add a little heat and they should come right out.
Stumpalump
12-26-2006 16:01:19
Just curious but are they Champion plugs? I heard they break and was wondering if other brands do the same.
super red
12-26-2006 16:11:50
 Re: spark plugs broken off in reply to Stumpalump, 12-26-2006 16:01:19
it was a champion plug .
dan hill
01-25-2007 02:34:11
 Re: spark plugs broken off in reply to super red, 12-26-2006 16:11:50
Champion plugs are made in Mexico now.Dont use them....The us made plugs never did this.This is a common problem with champion plugs.Had one break in an olds v8.Piece came out with a ezyout no problem.Old cracks made me think the shell cracked on installation.
davpal
12-26-2006 15:14:21
I had it happen in my ford truck one day. The plug rusted in half. If you have already put the penetrating oil the easy out should work. I used one. It takes a pretty big one. I think I had to drive it in there with a socket extension and a hammer. Once I got it seated very well I just used a lot of steady pressure and it turned right out to my relief. You may be able to even heat it with a torch if you have to. If you get it red hot it should spin right out. Careful, don't catch it on fire. Good luck.
