Restoration & Repair Tips Board
coil case vac 14
Troy ulrey
12-14-2006 19:59:28
Bought a 54 case that had been converted from 6 to 12 volt Tractor did not have a coil on it when i bought it what kind of coil should i ask for when I go to the parts store
souNdguy
12-17-2006 07:01:22
 Re: coil case vac 14 in reply to Troy ulrey, 12-14-2006 19:59:28
A NAPA IC14SB is a true 12v coil.. no internal resistor, no external resistors required.. about 15$....
Soundguy
John T
12-15-2006 05:59:09
If you wanna go with a straight 12 volt coil and NOT mess with any series Ballast Resistor, you need, obviously, to ask for a full true 12 volt coil (might wanna add for an old fashion points n condensor ignition system) what some refer to as an "Internaly Ballasted Coil".
Such a Coil might be labeled "12 Volts" or "12 Volts no external ballast required" but CAUTION DO NOT get one labeled "12 volts for use with an external ballast rersistor" cuz thats in reality a 6 volt coil.
A full true 12 volt coil will have around 3 ohms primary resistance as measured between its lil + and - terminals while a 6 volt would be more like 1.25 to 1.75 or so ohms.
NOTE 1 If it had an external ballast before you would NO longer use that on a 12 volt coil only if you used a 6 volt coil.
NOTE 2 If youre at Neg ground, the new coil will wire + from the ignition switch and its - to the distributor.
Hope this helps and if I missed anything, sorry, post back any more questions.
John T
