Shawnspeed3
12-01-2006 09:50:36
Re: soldering steel lines in reply to Ronnie/Bob, 12-01-2006 08:57:17
just 3 things...clean , clean, and clean...heat the tube to boil some of the oil out scrub, heat again, scrub, wash wit MEK or denatured alchol, If the tube has any sign of a phoporus or zinc coating , that will have to be removed with a file/grinder. if the tube has a split, you would be wise to remove the damaged section and sweat in a sleeve,that would slide over where the break was. also I would recomend a silver /tin solder with a flux that is rated for about 1100 degrees , you have to get the steel to about that tempature to get everything flowing. The blue , pre-fluxed rods of silver solder(benzomatic) I have never had much luck with, I now buy my flux and solder at a reputable welding shop and have had much fewer problems. You also have to watch for overheating, if the flux goes from liquid to white powder and then the powder residue melts,and starts wicking you are getting close,start trying some solder, watching for it to wick, if you keep heating too long, the flux will go back to a solid state and turn black....let it cool down, scrub everyting clean again and start over. I hope this helps..Shawn
