Restoration & Repair Tips Board
chev pick up
11-18-2006 14:21:50
I am trying to drain my radaitor in 1998 chev. with a 350 motor what is the trick? I do not see any logical way to get to the drain .
old wrench
11-22-2006 06:50:10
 Re: chev pick up in reply to [email protected], 11-18-2006 14:21:50
Or you could loosen the bottom hose
bradk
11-18-2006 15:01:48
They are kinda tough.I use a small slip-joint pliers to open them from the top.The trick is to pull out and turn at same time.~brad
jand38
11-18-2006 16:00:22
 Re: chev pick up in reply to bradk, 11-18-2006 15:01:48
I have a battery box in the way and have not found a way to remove it and the battery is on the other side
