Restoration & Repair Tips Board
getting hydralic fluid in transmission of ford 600
mustcycle2
11-15-2006 18:14:46
Iseem to be getting hydralic fluid in my transmission. so much so that it starts too ooz from the starter button. has any one had this problem and if so what is the cure? i suspect the seal has gone bad between the hydralic resivor and the transmission
lonzo
12-09-2006 18:46:08
 Re: getting hydralic fluid in transmission of ford in reply to mustcycle2, 11-15-2006 18:14:46
the seal behing the trans case the seals the out put shaft is giving you all the trouble, split the tractor at the back of trans case and you will see the troubles, it's easy, the tractor is light and easy to handle if you will hold the front part with stands or blocks and jacks and roll the back half away with a floor jack.
souNdguy
11-16-2006 06:29:30
Could be the tubes running from the pump also.
Soundguy
