Restoration & Repair Tips Board
Wiring lights on a 4020
polaris96
11-04-2006 04:00:15
I am attempting to wire lights on a 12v positive ground system. The light switch is wired to supply ground to the outputs. Is it possible to replace the ground input with 12v? Will the switch contacts be able to handle the amperage draw for the lights? I could also leave it as is and use relays for the lights. Any suggestions?
polaris96
11-05-2006 01:44:10
 Re: Wiring lights on a 4020 in reply to polaris96, 11-04-2006 04:00:15
Its a Diesel with 12 volt system.
Bob
11-04-2006 11:41:21
Gas or diesel?
24-Volt diesel converted to 12-Volts???
