Restoration & Repair Tips Board
Old H won't shift
ibcnya
10-30-2006 17:34:26
I have a 1950 International model H that has always been reliable. I was pulling a car yesterday and when finished went to shift into another gear. At first I could shift into any gear but when letting out the clutch it would bog down the motor like it's under a load but go nowwhere. 5th gear worked but no other gears would. Then after messing with it for awhile I could no longer shift into 5th but when in neutral the clutch will engage if let out and I'm still in 5th gear. I can shift into any gear but 5th now because that's in neutral. Any info is greatly appreciated. Hopefully the repair cost is less than the worth of the tractor.
neblinc
10-31-2006 06:30:22
 Re: Old H won't shift in reply to ibcnya, 10-30-2006 17:34:26
Here is the link with more info.
neblinc
10-31-2006 06:16:43
It sounds like the end of the shifter is worn and needs to be built back up. It is easy to remove and take a look in the hole to see if you are stuck in 2 gears. All the notches need to line up to be in nuetral. Post this in the Farmall Forum to get more info. This subject has been covered quite a bit, and there are some photos of what the shifter end should look like.
Randy
Keevin
11-04-2006 16:08:55
 Re: Old H won't shift in reply to neblinc, 10-31-2006 06:16:43
I can't remember what is next to 5th , but say 3rd is. Put in in third and try to get your shifter half in 3rd and half in 5th and bring both back to neutral. Works on my M. If that don't work pull the top off and do what they say. Later....
