Restoration & Repair Tips Board
Oliver Super 77 hydraulic leak??
simmonsx5
10-29-2006 07:14:12
When I add fluid to my hydraulic pump resevoir, I get leaking out of the end of the axle (onto the tire). The pump itself was just rebuilt a couple of years ago, so I"m assuming it"s something under the pump. What should I look for when I take the pump off? Thanks in advance...
old
10-29-2006 09:09:11
 Re: Oliver Super 77 hydraulic leak?? in reply to simmonsx5, 10-29-2006 07:14:12
Had the same problem on my S88. What was wrong with it was the seals where the PTO shaft goes into the pump to drive the pump. Took the pump off and replaced the seals and all is well now. Also those seals being bad will make your brakes not work because they get oil all over them. The seals cost me I think around $5
Josh in Pa
10-29-2006 09:02:19
If you are loosing oil from the hydraulics and it comes out of the rear, either the pump seals are bad, or the O-rings between the pump and reservoir are bad. The pump could also be cracked, but if the hydraulics work, I'd say thats unlikely. Don't forget to pull the pto shaft before you remove the pump.
Josh
