Restoration & Repair Tips Board
power steering problem
Russ Bernard
10-24-2006 23:19:15
I have a 64 ford 4000d tractor.I drained the power steering fluid out of the system, after finding water in the fluid. After filling the unit back up, the power steering will not work. It was working fine before I changed the fluid. Any thoughts??
Russ
old
10-25-2006 08:31:35
 Re: power steering problem in reply to Russ Bernard, 10-24-2006 23:19:15
You may still have air in the system and air doesn't pump well. Jack the front end up, make sure the fluid lever is full and then start the tractor and turn the wheels all the way one then then the other. Check the fluid level often. Doing that will get the air out of the system
Russ Bernard
10-25-2006 15:06:20
 Re: power steering problem in reply to old, 10-25-2006 08:31:35
Hobby Farm
Thank you for the advise, I will give it a try! I saw on your website, you have a couple alice chalmer tractors. I have a alice 52 ca, I use as a back-up. Great tractors!
Russ
old
10-25-2006 15:26:57
 Re: power steering problem in reply to Russ Bernard, 10-25-2006 15:06:20
I think all older tractors arew nice, just some are nicer to have then others are. Right now I have between 30-35 of them on the place.
