Restoration & Repair Tips Board
int. H tractor grinding noise
kevin Peters
09-18-2006 06:33:27
When I release the clutch with tractor in gear there is a grinding noise coming from drive train,the steady bearing or support bracket for the drive shaft between clutch and transmission,it is worn out, can you purchase this item, it is a farmall int, H tractor 5 speed
neblinc
09-20-2006 07:24:26
 Re: int. H tractor grinding noise in reply to kevin Peters, 09-18-2006 06:33:27
You may want to post this in the Farmall forum.
Randy
