Restoration & Repair Tips Board
Wiring amp meter
Damon
08-18-2006 15:03:36
Hello, found this site while looking for parts for my 8N. Anyway, I replaced a missing amp meter on my 1952 8N. The original one and its wires were gone when I got the tractor. Gauge is in, but where do I connect wires to to make the gauge work correctly? Please e mail me directly, I don't know if I'll find this site again!
Thank you in advance!
old art
09-04-2006 19:24:52
 Re: Wiring amp meter in reply to Damon, 08-18-2006 15:03:36
the amp meter on a ford has no terminals it has a loup the wire from the battery goes through to the terminal block it works by induction if it reads backwards reverse the direction the wire goes through the loupe. old art
John T
08-18-2006 20:24:30
The input supply side of the ammeter generally has only one wire and thats to the hot ungrounded battery post, often via where the big battery cable attaces to a starter/switch. The other Load output terminal is what wires to the genny or the Voltage Regulators BAT output terminal plusssss ss the same terminal feeds hot voltage to loads like lights and ignition often via a wire to the switches BAT input terminals.
If its wired correct it should swing over to - discharge if you turn on lights or ignition NOT running but then swing over to + charge running if all works IF IT DOES JUST BASS ACKWARDS SIMPLY REVERSE THE LEADS
John T
