Tips wanted on rebuilding hydraulic rams
Richard Brittai
03-13-2002 22:34:53
Hello everyone. It seems that when it rains, it pours. First, one of the hydraulic cylinders on my kubota tractor started leaking. Within a month, all four cylinders for the bucket were dripping fluid. I'd like to try to rebuild these myself and have ordered the parts necessary from my dealer. Does anyone have any tips on this process? While I tear into my pickup on a regular basis, this hydraulic thing is totally new to me. Any help will indeed be appreciated.
tomp
03-14-2002 19:00:50
 Re: Tips wanted on rebuilding hydraulic rams in reply to Richard Brittain, 03-13-2002 22:34:53
I've put the seals in a Cat loader and a 410 JD backhoe. I found it a fairly easy job. follow the instructions in manuals or that come with the kit and keep everything clean as you can. don't forget that there is usually a set screw that keeps nut from turning that holds in the seal stuff. If you turn without unscrewing it will tear up your threads.
good luck
