Restoration & Repair Tips Board
runnin' rough
klupkes
07-31-2006 09:59:40
The ol" H is runnin" rough ... it started to sound to me (which I am no expert or pretend to be) like she is flooding out ... only smokes when first started, but cleans out. At first I thought it was electrical, so I replaced the plugs and wires, then the points, condenser and rotar... still the same ... I tried adjusting the carburator, but am sondering if only made it worse ... ideas? Also, starts great and will run without stalling out ...
old
07-31-2006 11:25:22
 Re: runnin' rough in reply to klupkes, 07-31-2006 09:59:40
I'm with Bill on this one also. Pull the hose from the air cleaner to carb and see what happens. If it runs better you know the air cleaner needs TLC, may have a dirt dobber nest in the pipe some place, or you have very dirty oil and needs to be cleaned and refilled any how. It will also tell you if the choke is open or part way closed and also if there raw gas in the air tube of the carb which could mean a problem with the float or needle
BILL MAR
07-31-2006 11:21:12
Have you tried unhooking the aircleaner to carb tube? see if it smoothes out due to a restriction in the air cleaner. bill m.
