Restoration & Repair Tips Board
Mf 35 generator problem
Rcb 22
07-18-2006 20:29:05
We purchased a remanufactured generator and bolted it on. This one has the oil hole on the bottom and the Field post is the one further away from the engine . On our old one the oil hole was on top and the field post was next to the engine. The ampmeter goes backwards when started. Is there someway we can make this work for our tractor?
John T
07-19-2006 05:21:05
 Re: Mf 35 generator problem in reply to Rcb 22, 07-18-2006 20:29:05
Did you Polarize the genny??? I suggest that before you run it anymore.
John T
rcb22
07-19-2006 13:04:56
 Re: Mf 35 generator problem in reply to John T, 07-19-2006 05:21:05
Yes I did.
souNdguy
07-20-2006 05:57:37
 Re: Mf 35 generator problem in reply to rcb22, 07-19-2006 13:04:56
If you polarized it correctly, then it should charge in the correct polarity.
Did you remove the battery an reinstall it backwards?
Soundguy
