Restoration & Repair Tips Board
farmall wont keep running
sam gordy
07-17-2006 03:04:06
i have this farmall cub i put everything new on it and it sti;; wont start,the only way it will is take the wire off the distruber from the coil and it will start if anyone knows what this could be please email me
old
07-17-2006 12:07:09
 Re: farmall wont keep running in reply to sam gordy, 07-17-2006 03:04:06
Well if it really has a distubutor it couldn't start that way. Now if you have a mag thats a differant story and that wire would be the shut off which grounds the mag. If it is a mag then you have either a problem with the wire being shorted or the switch is bad, or and not likely is you have the switch in the wrong position when you try to start it. Now by the way you explained it you leave a lot of gaps/not enough info to really say. If you have a distubutor /battery ignition the coil will have 3 wires on it. One is the hot of distubutor cap wire, one is the battery side/power and the last one is the points side.
