Restoration & Repair Tips Board
internatial cub tractor
samuel gordy
07-12-2006 05:16:16
I have put everything new on it and it still wont start if i take the coil plug off the distruber it will start what could be wrong with it?
souNdguy
07-20-2006 06:13:44
 Re: internatial cub tractor in reply to samuel gordy, 07-12-2006 05:16:16
Coil plug OFF the distrib.. and it WILL start? That's backwards.
Do you perhaps have a magneto?
Perhaps someone swapped a magneto onto an a cub that had previously used battery ignition , and you are wireing the magnetor 'kill' line up to the coil, thus killing the maggy
Post pics.. there is usefull info missing that is needed to diagnose this problem..
Soundguy
sam gordy
07-20-2006 09:23:51
 Re: internatial cub tractor in reply to souNdguy, 07-20-2006 06:13:44
yes it has a magneto and a battery ignition,what it is you can take the coil wire off and hold it next to the plugs and it will start and keep running but when you put the plug wire back on it quits just cant figure this out was hopeing someone would
thanks
souNdguy
07-20-2006 10:32:08
 Re: internatial cub tractor in reply to sam gordy, 07-20-2006 09:23:51
Ok.. you are not doing a real good job of getting clear info out to us to help you fix your tractor.
First. Plug wire away from the spark plug.. this makes sense.. it means you have fouled plugs most likely.
Now.. your tractor can't have both a battery ignition system, AND a magneto, unless it is a shelled out magneto with a coil manually butchered and wired in using the magneto points.. etc.
So which is it? standard battery ignition? Or magneto? Or a hybred magneto that has been shelled out to allow for a shadetree battery ignition system??
the more info you provide.. the better the answers will be.
Also.. there isn't any charge for more words in your post.. please be very clear and descriptive.
Soundguy
sam gordy
07-21-2006 14:51:35
 Re: internatial cub tractor in reply to souNdguy, 07-20-2006 10:32:08
it is a hybred magneto that has been shelled out to allow for a shadetree battery ignition system
souNdguy
07-22-2006 21:11:38
 Re: internatial cub tractor in reply to sam gordy, 07-21-2006 14:51:35
Then it needs to be wired up pretty much exactly like a regular battery ignition system. I.E. an ignition switch to cut power to the coil, etc, as well as having a connection fromt he coil tot he points.. etc.
And your spark plug fireing issue, as said, is most likely fouled plugs.
Make sure you have a coil that matches youe battery polarity and voltage, and make sure you use metal core wires,.. not carbon core.. they cut your high voltage down, and can sometimes cause the fireing problem you are seeing.
gap your points like the battery ignition settings, if there is a difference between that and the magneto settings..
Soundguy
