Restoration & Repair Tips Board
Oliver Super-55
R. Hensley
07-09-2006 06:30:18
Hello,
I own a Oliver super-55. It has reverse but no forward gears at all. Does any one have any ideas on what may be wrong with it? I bought the tractor this way and I have know idea what may have caused this problem.
Roland
jake4
07-09-2006 10:28:11
 Re: Oliver Super-55 in reply to R. Hensley, 07-09-2006 06:30:18
If you are lucky the shift rods are misaligned. To check this pull the shift lever off being sure not to lose the 2 springs [right& left] which keeps the lever centered. To check alignment you will see 3 rods the center is hi-low and has 2 flats ground. The outer 2 rods have verticle ground flats ground. To line up take a long screwdriver move the center rod till it stops [forward] the slide the R & L rods forward till all forward slots line up, then reinsert the shift lever[w springs] This most likly is the problem. I had one with loose screws on the fork which required removal of the hydraulic cover but most likly likly the rods. I can send scans if needed. LOL
Roland Hensley
07-26-2006 08:37:28
 Re: Oliver Super-55 in reply to jake4, 07-09-2006 10:28:11
Thanks Jake, you were right on, it was the shifting rods that were misaligned. I had it fixed in about a half-hour. Thanks again, you saved me alot of time and work.
Roland
