Restoration & Repair Tips Board
Valve lash adjustment
Paul Tn.
06-16-2006 22:11:52
Can someone tell me how to adjust the valve lash on a 1996 Buick Century 3.1? I had a coolant leak and had to replace the intake manifold - head gssket and in doing so had to remove the push rods. I have it all back together and now ready to adjust the valve lash.
Haynes says they are pre-set and not adjustable. On another page Haynes list rocker arm nut torque as 89 in-lbs and then tighten an additional 30 degrees. If I use this 89 in-lbs torque procedure, what are the different steps I need to go through to get it right.
Thanks Paul Tn.
