Restoration & Repair Tips Board
Super C Distributor
Steve Stanick
06-16-2006 05:44:04
The engine has been running rough when I discovered that one of the fly weight springs was broken. When I removed the distributor I noticed that the well the gear was in is void of any lubricant. What do I use, there is a set screw in the side of the mounting casting so I'm guessing 90wt oil?
Wayne Swenson
06-20-2006 08:15:12
 Re: Super C Distributor in reply to Steve Stanick, 06-16-2006 05:44:04
The set screw is so you can install a grease zerk (temporary) and give it 2-3 shots once a year. Do not over lube.
Bob
06-16-2006 10:40:31
If you have an IH distributor, I don't think there is a seal between the gear housing and the distributor, so you wouldn't want to use oil!
AFAIK, they had grease in them, originally. I use wheel bearing grease. Don't put too much in there!
