Restoration & Repair Tips Board
steering box on 8N
jv texas
06-06-2006 19:15:35
I went to put some Corn Head grease in my steering gear box only to find it doesn"t have a plug to do so. The only thing visible are the two adjustment screws and related mounting bolts on either side. How do I put this grease in there? Any tricks to it? I unscrewed one of the mounting bolts to see if it was a "through" bolt, but it wasn"t...
coastie
06-06-2006 20:15:45
 Re: steering box on 8N in reply to jv texas, 06-06-2006 19:15:35
On my "50 8n, on the right side, couple of inches above and a little to the right of the adjustment screw is a bolt that holds sheet metal to the steering box, that is where I fill my box. check it out with a piece of wire, it should be hollow. fill it till it comes out by the steering wheel. John
