Restoration & Repair Tips Board
TO35 Gear Oil Leak
John Ellingson
05-22-2006 14:26:24
I changed the gear oil in my Ferguson 35 about two weeks ago. On Saturday, it started leaking out through my STARTER! What's up with that? Can anybody offer suggestons about what's going on?
souNdguy
05-22-2006 18:29:49
 Re: TO35 Gear Oil Leak in reply to John Ellingson, 05-22-2006 14:26:24
Assuming it was gear oil you saw.. and not crank case oil.. I'd guess that you have a bad 3$ tranny input shaft seal (leaks), and that you probably overfilled the sump, and also that your bellhousing drain is plugged up... etc..
Soundguy
John Ellingson
05-25-2006 15:58:16
 Re: TO35 Gear Oil Leak in reply to souNdguy, 05-22-2006 18:29:49
Thanks for the help. I'll check that out. Pretty sure that it was gear oil. That stuff was pretty thick.
john
