Restoration & Repair Tips Board
TO 35 hydralic stuck in up position
Jim Mayers
05-20-2006 04:55:12
Any advice would be appreciated. The three point hitch is stuck in the up position. As soon as the tractor starts the hitch goes up. Obviously the lever no longer works. It never did feel any pressure against it when it did work. My question is it best to remove the cover under the seat and do the arms through the side remove easily?? The plate is held in place with 12-15 bolts and has a crack in it. I have previously been advised to remove all hydralic oil and go through the side plate(s). Need advise. Never had the guts to take it apart. Thanks.
Jim
