Restoration & Repair Tips Board
how to shorten a tach cable?
Dan (wi)
04-28-2006 19:50:15
wish to shorten the inner drive cable & replace that nice little square end,as Ive found a replacement cable but its a little long.thanx Dan
gab
04-29-2006 08:07:17
 Re: how to shorten a tach cable? in reply to Dan (wi) , 04-28-2006 19:50:15
Don"t know if a tach cable is the same as a speedo cable, but there"s a tool to square up the one end and a universal cable kit had a plastic upper end. You cut the cable to length, heat the cable end and slide on the plastic tip. Jim
HG
04-29-2006 06:58:34
When I worked in the truck shop we made our own cables, had a forming tool to make the square end. We would cut the inner cable to lenght and place it in the anvil type tool and smack with a hammer. It made the square shape with one whack. Only takes a few minutes in all.
I'm sure some older truck shops still have that tool.
Illinois Boy
05-10-2006 12:42:44
 Re: how to shorten a tach cable? in reply to HG, 04-29-2006 06:58:34
I used a speedometer replacement cable (inside cable) to fix the tach on my 350 - worked like a charm and can be cut to any length. One end is squared already - the other end gets a crimp on square fitting installed. Crimp tool comes with the kit. I think it came from AutoZone but any parts place should have "em.
