Restoration & Repair Tips Board
PTO disengaging
JD Foreman
04-12-2006 09:27:31
I have an IH 404 and after about 30 minutes of use, the PTO started to chatter like it was skipping teeth on a gear and then it disengaged. When I put the clutch in and reset the PTO handle, the PTO would work fine for a while but when the going got tough, it would slip again. I also found that I can push the PTO output shaft in and out about a half inch.
Is the gear excessively worn or do I just need a bushing of some sort?
Can you get to the internals by just removing the cover plate or do I need to remove the whole PTO as a unit?
What"s a good hydraulic fluid for these old tractors?
Thanks!
