Making your own seals
res
03-02-2002 04:20:16
What material is best to use for making your own seals for radiator cap or inspection plates on the block, where it will be opened multiple times?
Rod (NH)
03-02-2002 19:07:06
 Re: making your own seals in reply to res, 03-02-2002 04:20:16
I'd use the gasket material that comes in rolls that you cut out to suit any particular need. It is available at NAPA in both fibre and cork materials and in different thicknesses. If you want a rubber type gasket, I suppose you could cut up an old inner tube...I have done that before.
Joe (Wa)
03-02-2002 19:48:36
 Re: Re: making your own seals in reply to Rod (NH), 03-02-2002 19:07:06
Thanks Rod, you just solved my problem in finding a suitable replacement for the cork faced friction disc on the hand throttle for my 311b. Cork I don't like, innertube matl should be just the ticket. Regards Joe.
