Farmall 300
Followers of We
04-13-2008 15:14:44
Does anyone know where to get a spacer block for when you take the hydraulics off of Farmall 300?
Farmall 47
04-15-2008 18:21:52
 Re: Farmall 300 in reply to Followers of Weber, 04-13-2008 15:14:44
I went through this last year. If you want to take live hyd pump out you also have to replace the front plate behind timing gears with an H plate to use the spacer from an H. ChadS is right the holes will not all matchup. I chose to take the gears out of the pump. There is a thrush washer also that I removed. I put a breather in the top and put oil back in. At the bottom where the lines would have been I made a plate and used the original o-rings to seal it off. Has not leaked and works fine.
wls
04-14-2008 21:19:53
i belive you need a farmall H spacer I have one if you are interested
ChadS
04-15-2008 05:31:28
 Re: Farmall 300 in reply to wls, 04-14-2008 21:19:53
Im not sure if the H spacer for the distributor housing will fit on the 300 timing cover,,, 3 bolts will line up, but not all 4,,,, may have to swap the timing covers to make it right, if your trying to remove the hyd pump,,,,, I wouldnt ruin a good hyd pump by running it dry. ChadS
Mopower
04-14-2008 17:44:20
I have some 300 hydraulic parts but not sure what part you are describing.
Haird7
04-14-2008 08:49:33
Exactly where are you talking about needing a spacer block?
