SM, LP w/ 8060 head how mmuch to shave/
John A.
04-12-2008 20:33:08
Guys, have a 53 Stage I, SM-LP with 8060 head. I want to plane/shave the head to get a little more power out of her. I will be pulling a shredder and normal farm cchores.
Will be useing step/domed pistons, how can one measure the amount of free space in the top of the head w/ pistons at TDC! Or does annyone know how much can be removed and still be a good serviceable head.
Later,
John A.
mEl
04-13-2008 04:57:41
 Re: SM, LP w/ 8060 head how mmuch to shave/ in reply to John A., 04-12-2008 20:33:08
Don"t know much about building Farmalls but we find the popup volume by dropping the piston down the bore till the popup is flush with the top of the sleeve, then grease the piston edge to stop any leakage of fluid, then cc the cylinder to see how much the popup displaces, remove that figure from your head volume when computing static C/R. I have heard many horror stories similar to Jim"s about planing Farmall heads, I am runnung a DC head with .135 off it and never experienced a problem. Good luck with your project! mEl
james rumph
04-13-2008 04:15:29
I have a 8060 that .125 was removed and that caused problems! The corners of the combustion cracked down to the valve seats.
The chambers are "D" shaped and they crack in the very corners. This is a common problem that leads to coolent in the oil.
It would be smart to have it magna fluxed first to check for cracks. Any automotive machine shop can do this.
If it is good just cut it .062 [1/16] and what you remove from the deck surface you will need to make the same thickness shims for under the rocker stand pedestals.
With only .062 off ,your adjustment nuts are still useable on your rockers but it puts them out towards there limits.
I made .125 shims for my 8060 head to keep the adjustment on center. My 450 gas head has had .062 cut off it and it has .062 shims under the pedestal to keep them on center.
It will run fine with the .125 cut off it and i had fire craters in the motor. I didn't have heating problems but the head is thin in some areas around coolent passeages. I think it was to much and caused the cracking due to the strength of the material being removed.
I had it repaired in "6" spots and it ran fine , but i got milk in the oil!
A good head gasket is important , spray it with copper as well before installing it. Retorque it after the motor is good and hot.
I hope some of my problems help you avoide the same grief.
Good Luck
James Rumph
