WD-45 Starter?
The_Rook
04-09-2008 06:33:14
Does anyone know of a gear reduction starter setup that would work on a large cube WD-45? Thanks!
doug boll
04-09-2008 10:23:57
 Re: WD-45 Starter? in reply to The_Rook, 04-09-2008 06:33:14
we put a M&W gear reduction on a Case with hi-comp. Seems to do the job. They made them for AC, 1.7to1 reduction, don't know how hard to find but $100 was a better deal than a $325 gear reduction unit!
mlpankey
04-09-2008 10:13:23
been there done that past through it . give me a call after 5 eastern standard ill tell you how to spin it faster than it needs to be to start it . 423 472 7071
mlpankey
04-10-2008 05:54:57
 Re: WD-45 Starter? in reply to mlpankey, 04-09-2008 10:13:23
must not be as bad a promblem as he thought cause ive not heard from him as of yet . high compression large cubes do need a liitle more starter but hey even a dummy like me figured out how to start mine then told kerry hensley how to get his big cube to start . he has been tickled with the build up when i told him what parts to use or so he was the last time i spoke with him.
The_Rook
04-10-2008 07:18:36
 Re: WD-45 Starter? in reply to mlpankey, 04-10-2008 05:54:57
Sorry mlpankey I didn't get ahold of you last night, been very busy with side-jobs in the evening this week. If it's ok, I will give you a call this weekend?
mlpankey
04-10-2008 08:14:47
 Re: WD-45 Starter? in reply to The_Rook, 04-10-2008 07:18:36
no promblem . idont charge a thing to give you some options . then when you decide what option youll know where to get the parts to upgrade . cause im not in the parts selling buisness either . takes all my time to work and play with my old puller.
